Ir para o conteúdo principal
Repair guides and support for televisions manufactured by Panasonic.
576 Perguntas Visualizar todos
Wont turn on..Front L>E>D. flashes 10 times
Panasonic TH-42PZ80U Television
Plug the power to TV the L>E>D> flashes 10 times....pauses then flashes 10 times...keeps repeating.
Ive opened the back cover thought I would try blowing out the dust bunnies..no change.
So I thought I would order a Main Brd. which I did and it hasn't arrived yet. So I was doing more research and Ive found the 2 IC's on 2 separate daughter boards on the Power Supply brd. so I sprayed then with refrigant to freeze them...I did one at a time...and I found one that once I sprayed it..and it was frozen I can power on the TV without any issues...so instead of replacing just that IC and the capistator I thought I would just replace the power board. My concern is on the Power Brd I see a number of NPX702MF-1A and Ive found that part on Ebay but I also see NPX702MF-1 which is a
little less expensive...would that brd work?...or what are the differences?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@krc9529 you are absolutely right. The 10 Blink code is most commonly related to a failed PSU. The differences in those power boards may just be related to different version/layouts. Always make sure that the connectors are of the same type and in the same location. There are no good schematics out to do a side by side comparison. I would discuss this with the vendor and purchase it if it has a straight forward return policy.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
gerg45uerf34 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 186
