Ir para o conteúdo principal
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Perguntas Visualizar todos
Pergunta encerrada
Is my harddrive about to go?
Hello,
My harddrive is making noises i never heard in 3 years(it is a odd sound when being used at times)
Should i get my external harddrive and make a backup?
All i know is i have constant curuption issues
I know what i am buying for this computer when this drive goes
Also,i heard a light "click,click,click" starting Safari
im getting a WD scoropio black 500GB
Update
So far i am backing up my iTunes on it
All i need off is a handfull of files
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
5 respostas
Solução escolhida
A drive that is making repeating clicking sounds is toast, period. There is no redeeming a drive that has reached that level, and no piece of software can save it, because you're dealing with a hardware issue that is not going to improve. Back up your data, replace the drive, and move on. You can keep using it of course, but go forward with the expectation that it will soon fail completely and whatever data is on it will soon be irretrievable.
Esta resposta foi útil?
Pontuação 1
7 comentários:
I need it for 2 more months,then i can swap it out
por
or i will stop making files on it
por
I am shocked the drive is going this soon but i cannot afford a SSD at the moment
por
How long have you had the drive? Is it still in warranty?
por
its the stock one the computer had when i got it
por
Exibir mais 2 comentários
Pergunta mais útil
I would back it up as soon as possible. Apple includes hardware diagnostics, Apple Hardware Test (AHT), usually on the first disc of your recovery set. Some of the newer models have it built in as well by holding down the D key during boot.
Pontuação 1
1 comentário:
I have discs from a late 2007 macbook pro because Apple flat out replaced it for me when i had MOBO issues
por
Try downloading Data Lifeguard Diagnostic from Western Digital Corporation to get an idea of what is happening. However, backup, backup and backup
Pontuação 0
Open up disk utility and verify the drive straightaway. Also make sure you have backups.
Pontuação 0
1 comentário:
If you are having corruption issues the use DiskWarrior
por
Your hard drive has been physically damaged and only option left to save your data is search a data recovery services company. They has experts you can recovery your data from all possible conditions.
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 893
