Ir para o conteúdo principal
Repair guides and support for battery-powered toothbrushes.
20 Perguntas Visualizar todos
Battery problem in Braun electric toothbrush 3D D 15511
Can this can be repaired
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
In theory yes, in practice...that depends. I have a similar model that failed and I opened it up to see if I could just replace the battery, The problem was everything was corroded to near death inside. The battery is not designed for easy replacement and everything is soldered in place. I found the defective components and was able to order them (IC's & Battery) but the logic board was in very bad shape.
So I would certainly try, otherwise the tooth brush will just end up in the trash. Hopefully you'll have better luck than I did.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Farida Zainulabdin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 150
