Ir para o conteúdo principal
O DJI Phantom 3 Advanced é um sistema de voo controlado remotamente, lançado em abril de 2015. Número do modelo: WS22
Gimbal roll error message
After a crash that broke the yaw arm and ribbon cable, I replaced both, and replaced the bent camera tilt motor too. Now, camera and gimbal do not move on start up or at all! I am getting a camera feed to the app, but camera and gimbal do not respond to any calibrations. I'm getting gimbal roll error message in app. Should i replace the entire gimbal camera as I've already replaced every part that was broke, or could this be inside the drone itself? I did remove top cover to inspect for any detached harness, but found nothing out of the ordinary.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
I am having the same problem, however, mine is saying "gyroscope error"... I don't know how to proceed.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Joe Gustafson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 27
Ao todo: 1,977
