Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2264 Perguntas Visualizar todos
Black Screen for Both Cameras and No Flash after Screen Replacement
Yeah like the title states. I am at a loss. Everything works but both cameras and flash.
I even replaced:
Buttons Flex Cable
Front facing camera flex cable
Rear Camera Assembly
So only thing I can figure out is maybe the connections the motherboard itself.
Anyone find something obvious that I am missing?
Update (07/17/2017)
Yes there are really only two connectors according the logic board map that affect these. I will take a very careful look at both tomorrow and get back with you.
It would be crazy if that was it.
I think I have been overthinking this.
Thanks man. Will report my findings.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Was three capacitors near the display connection. Two bent and one broken off. They tried to fix it. Even soldered a new one from another board. No dice.
Cameras didn't work, and the phone stopped accepting a charge.
Thanks for the help man.
por
Adicionar um comentário
1 resposta
Solução escolhida
Take a good look, preferably with magnification, at the connectors. You want to inspect for bent or damaged pins or missing components near the connectors. Let us know what you find by commenting on this answer.
Esta resposta foi útil?
Pontuação 2
1 comentário:
I couldn't see anything wrong. I looked thoroughly. Sigh. So close. I might have missed it but I may take it in to get it checked out and hope they don't charge me 700 bucks
por
Adicionar a sua resposta
Therin Whitten será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 103
