Ir para o conteúdo principal
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
131 Perguntas Visualizar todos
Vertical lines on lcd after display replacement
I recieved an iPad Pro 12.9" in for repair from another shop. They bought a new display with the daughter already attached, but it is showing a bunch of vertical lines down the right center and nothing else. It doesn't look like they disconnected the battery while replacing the display so im not sure if its just a faulty display or they damaged something on the board. Thanks in advanced!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I have not had to order any 12.9" screens yet but from what I have read on the tech forums, they appear to be quite problematic. I would certainly explore a return or refund with the supplier.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Daniel Grueneberg será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 229
