Ir para o conteúdo principal
Segunda geração do iPhone. Modelo A1241 / capacidade de 8 ou 16 GB / parte traseira de plástico preta ou branca. O reparo é mais direto do que no primeiro iPhone. Requer chaves, alavancas e ventosas de sucção.
Error 6 fix?
I've been trying to reinstall iOS 4.2.1 on my old 3G iPhone, but it throws back error 9 or 6 every time. I've already tried most of the common solutions. Can anybody offer any assistance? Thanks!
Update (06/17/2017)
I also forgot, it's stuck in DFU mode, and the iOS was corrupted when I got it.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Try to flash with 3Utools
Esta resposta foi útil?
Pontuação 3
3 comentários:
are you sure all the connections are fine? dock and cable I mean.
por
Yes, and I was doing it wrong anyway. :) I downloaded the actual program, and it fails at 13% saying invalid serial number.
por
This tool is very useful~ And about invaild serial number, you can try to enter your device to DFU mode and flash again.
por
Your device is stuck on DFU, you can exit that with 3uTools.
Imagem
Pontuação 1
2 comentários:
With the serial number issue, it refuses to flash. It's also stuck in a somewhat damaged DFU mode, so the only way I can get it to even begin the process is by cheating with iTunes and unplugging it once it reenters recovery mode. I'm honestly a little stumped on this.
por
If serial number issue issue still exists, there may be hardware issue. You are suggested to get a repairman to check your device.
por
Adicionar a sua resposta
Nikola Wozniak será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 24
Ao todo: 662
