Ir para o conteúdo principal
Screen discoloration in top right corner of iPhone 6 Plus, please help
I replaced the front panel on an iPhone 6 Plus last night. I tested the LCD before installing all of the components (front camera, speakers, home button, etc.) into it, and it seemed to work fine. I even did one more test run before I closed the screen to make sure all of the cables were connected well, and it worked perfectly. When I closed the screen, however, a bright spot had appeared in the top right quarter of the phone. I have had two other 6 pluses with identically shaped and positioned bright spots, so something I am doing wrong must be causing this. Please help me with any information you know.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
It would be helpful if you posted a picture (you can add it to your question).
Generally speaking, white spots are caused by pressure. So if you have a bright spot in the top right corner, look at the camera and screen bracket area for something that isn't installed or lined up properly. It could also be a batch of poor quality screens where there is some dust or something else sandwiched between the LCD and backplate (this would be a very small white spot though).
Esta resposta foi útil?
Pontuação 4
1 comentário:
I had a white spot also. It was the battery pertruding slightly on the upper left edge (original battery and screen). I solved it by lightly pressing down the edge of the battery with the flat end of a plastic spudger.
por
i think it has no solution take it to apple authorized centre
Pontuação -1
Adicionar a sua resposta
Garrison Bates será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 6,108
