Ir para o conteúdo principal
A versão somente wi-fi do Air iPad, da Apple, modelo número A1474. Disponível nas cores cinza espacial ou prata, conta com o processador A7 personalizado, com configuração de armazenamento de 16, 32, 64, e 128GB.
Replacement digitiser now misbehaving
Replaced the digitiser after daughter cracked the screen, worked fine at first (although I didn't test the responsiveness of the entire screen - assumed if you could unlock the device with a PIN, open some apps, it was good). About a week later it seems to behave sporadically (either sometime not respond or open random apps / type random characters). Seems worse one horizontal orientation that the other. This was an aftermarket replace, could that be the cause? Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
Poor quality aftermarket digitizers could certainly cause this. Some of the cheap ones suffer from ghost touching as well. It could also just be improperly connected or you may have kinked the flex when you did the repair.
Lesson learned, always check the entire surface of the digi before sealing it with adhesive :>)
Take a look at the ones iFixit sells, they are good quality.
Imagem de Replace a front panel assembly compatible with iPad Air. Assembly includes the glass touch panel (digitizer), blank home button, camera bezel, and adhesive.
Produto
iPad Air Screen Digitizer
$29.99
Esta resposta foi útil?
Pontuação 3
1 comentário:
Thank you. I'm in the UK hopefully they ship here
por
Maybe you have a defective screen but before ordering another check if putting pressure on the bottom part of the screen left and right of the Home button. If this causes your screen to touch by himself the solution would be to put some tape on the little components marked with red and tape also the bottom part marked in green.
Sow you have some component on the home button flex which are not always isolated, the little cercle.
And sometimes you have the bottom part of the digitiser showing the lines which go to a segment of the digitiser that need isolation also.
Pontuação 2
5 comentários:
Great I'll give your suggestion a try. Thanks
por
Looks like this could be the problem, pressing either side of the home button causes the problem. Forgive me but its not clear to me from the photo which parts I need to cover. Do you have any other photos or instructions? Thanks
por
Only monday once i'm back at the shop, i'll add a more detailed photo to the answer
por
Thanks. Any luck with the photos please?
por
Hope it helps
por
Thanks for the advice, I tried covering the areas mentioned with tape but no improvement (pictures below). Purchased another screen which is now installed & seems to be working well, lets hope it lasts.
Pontuação 0
Adicionar a sua resposta
JohnyB será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Ao todo: 202
