Ir para o conteúdo principal
Guias de reparo, informações de desmontagem e resolução de problemas para a 5ª geração do Apple iPad com 4G LTE, disponível com 32 ou 128 GB de armazenamento. Lançado em março de 2017. Identificado pelo número de modelo A1823. Possui tela Retina de 9,7" e processador A9 de 64 bits.
How can I swap out the home buttons with ipad air digitizer?
I replaced the digitizer on 2017 iPad and want to know if I can also swap out the home buttons?
Esta é uma boa pergunta?
Pontuação 0
3 comentários
Most of us have not seen this one yet. Would you let us why you do do this?
por Compartilhar
Well, in my case my screen shattered and so removed the screen but also ruined the home button in the process. So I simple removed the old home button and have ordered a new one. Hopefully it'll go back together no problem fingers crossed. I'll update when I get my new home button.
por Compartilhar
touch id will not work if you replace home buton
por Compartilhar
Adicionar um comentário
3 respostas
Solução escolhida
The big one, is the Air 1 digitizer cross-compatible?.
Also, check here.
I haven't confirmed this personally so caveat emptor.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Answer: yes.
The original iPad Air Digitizer works as a replacement. Be careful when removing the cracked or bad digitizer as the home button comes off in the same way that the original Air does. The 2017 model has sensors on the cable for TouchID. Simply take the original home button off the 2017 model and swap it onto the replacement digitizer.
Pontuação 4
Hello, ran into this same issue and here is what I found:
Basically the digitizer works, but the button does not from the iPad Air 1st generation. Read my full post here regarding this same question:
Replacing/Repairing Home Button and Cables for iPad 5
Pontuação 1
Adicionar a sua resposta
mrayw1119 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 37
Ao todo: 2,348
