Ir para o conteúdo principal
Os fones de ouvido Sony Extra Bass, modelo MDR-XB450AP, são um par de fones de ouvido de alta qualidade fabricados pela Sony. Possuem um microfone omnidirecional para capacidades Bluetooth.
Sound is low and faint
I have just been given a set of Sony headphones model number MDR-XB450AP. When plug them into my computer and my iPod touch they work fine but when I plug the extension cable that I have the volume on headphone is low and faint. I know the extension cable work alright with other heads.
Update (05/02/2017)
Here are the photos that you wanted. Photo 1 is of the Sony headphones. Photo 2 is of the Sony headphone plug. Photo 3 is of the other headphones that work. Photo 4 is of the plug from the other headphones that work. Photo 5 and 6 is of the extension cable.
Imagem
Imagem
Imagem
Imagem
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 1
5 comentários
Hi,
Just wondering, is there sound in both the left and the right headphone?
Also do the other headphones that you tried with the extension cable have a 4 'ring' connector plug like the Sony, i.e. TRRS plug (tip, ring 1, ring 2, sleeve) or a 3 ring TRS plug (tip, ring, sleeve)?
If not the extension cable may not be suited to a TRRS plug (it should be but....)
http://www.cablechick.com.au/blog/unders...
por
There is sound in both the left and the right side of headphones. The other headphones I have tried I am not sure but I think they either have a 1 or 2 ring.
por
Hi,
Post some close up images of:
1 the plug from the Sony headphone.
2. the plug from one of the headphones that work with the extension cable.
3.the plug from the extension cable.
Here's how to do it Adicionar imagens a uma pergunta já existente
por
@jayeff looks like you are on the right track ;-)
por
Thanks for that help
por
Adicionar um comentário
2 respostas
Solução escolhida
Hi,
Your problem is that the "ground" connector" in the "female" socket of the extension cable is contacting the "microphone" connector in the Sony "male" plug and not the ground connector.
If you get one of these adapters to connect between the Sony headphones and the extension cable, it will solve the problem.
There are two main "wiring standards CTIA & OMTP" and depending on which particular one you have (and you might not know until you try it) and what you are trying to connect it to, this adapter will allow it to work for either one, unless you don't need it at all.
You do not have to buy a new cable.
Update (05/04/2017)
Hi Angela Cameron,
Just search for a 3.5mm 4-Pole TRRS Standards Bi-Directional Adapter and select the supplier of your choice.
Esta resposta foi útil?
Pontuação 3
6 comentários:
Thanks for everything. Do you know where I can buy online a 5m extension cable for headphones that doesn't cost a lot of money. It can be long than 5m but no shorter
por
So when I go to search for this on the internet what do I put in the search to find this
por
I am still waiting for an answer to the question I last asked
por
Hi Angela,
I posted the answer you wanted the day after you asked it on the 05/03/2017. It is shown under "Update (05/04/2017)" in the Most Helpful answer above.
It was placed there so you and others would not have to search through all the subsequent answers (if any, and any other questions which are in the answer boxes) to find it.
por
My sony headphones MDR-XB450 wired have problem the sound is there but vocals are only just recognisable any help would be great thanks
por
Exibir mais 1 comentário
Extension and Sony headphone not compatible. Simple terms, extension has 2 line on pin, heads have 3. So when you plug extension to port, you are only getting 2/3 of sound. Buy ext with 3 pins.
Pontuação 1
Adicionar a sua resposta
angela cameron será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 21
Ao todo: 6,910
