Why bike wont start
I have a 2013 thunder bird 1600cc sometimes starts with no problem, and other times power to gages and fule pump but when i hit the starter nothing not even a click?
Esta é uma boa pergunta?
@hectorpez ,Hector, That could be signs of a battery on it's way out or bad connection. Have battery tested, check all connections and wires for not being loose/corroded/damage in the starting circuit/on battery. See the link below as it discusses your issue. I have also attached a down loadable service manual at the 2nd link. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 29
Ao todo: 3,277
1 comentário
Check for correct gap of sparkplug (s) and proper plug size
por Robert Johnson
