Ir para o conteúdo principal
A Nikon N80 (também conhecida como F80) é uma câmera SLR de 35 mm. Foi lançada em janeiro de 2000 e é identificada pelo número de modelo 1776.
Is it a brick?
Hello!
I just bought a used Nikon N80. It seemed to be in perfect condition, but I took it home and discovered a focusing problem.
The image in the view finder is dim. And when I try to focus, the lens goes in all the way and back out to infinity without finding a focus point.
I tried a few lenses with the same result.
I checked the sensor at the bottom of the chamber, and it's clean.
Like I said, the camera seems to be in great condition otherwise.
What do you think? Is this a brick, or can I fix it?
I should also mention that I bought the camera with the lens improperly attached. I had to carefully cut a tiny piece of plastic off the lens mount to get it off.
Fortunately I paid only $20 for it, plus new batteries.
Thanks for any input on this!
Eric
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Eric Zulaski I wonder if you have trouble with the AF unit or if an adjustment would work. Since you are only in for $20 it maybe worth your while to get the repair manual from this page (under "Document") and go through the adjustment routines etc.
Esta resposta foi útil?
Pontuação 3
3 comentários:
Thanks for the tip. I will certainly give it a try.
por Compartilhar
I had been on the guide page, but I didn't notice the repair manual tucked in there.
por Compartilhar
It's a present added after you asked the question
por Compartilhar
Adicionar a sua resposta
Eric Zulaski será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 28
Ao todo: 629
