Ir para o conteúdo principal
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
523 Perguntas Visualizar todos
starter solenoid wiring diagram from battery to solenoid
Craftsman Riding Mower model27011 i need to know how the wiring diagram from battery to solenoid to starter is configured
Esta pergunta é pertinente?
Pontuação 7
Adicionar um comentário
5 respostas
Pergunta Mais Útil
@lawnboy707 verify your complete model number for us. This diagram should work for your mower.
Esta resposta foi útil?
Pontuação 3
@lawnboy707, John, Below you will find the manual and pic's/schematic of how wire's are hooked for starting system, for Model #502270111 CRAFTSMAN Lawn, Riding Mower Rear Engine. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.searspartsdirect.com/model-nu...
Pontuação 1
here is the wiring diagram i found at https://www.searspartsdirect.com/model-n...
Pontuação 1
2 comentários:
In the diagram there are the numbers "1-26". It would be helpful to have the key along with the diagram to help identify what each number correlates to. I.E. number 3 identifies the anchor bolt for the hot wire to the positive battery terminal
por
@Michael Dodson
If you click on the link provided in the answer above your comment you will get the Sears webpage where it came from.
Under the diagram on the page is a list of the part numbers as shown in the diagram and if you then click on the relevant part i.e. part #1 = Sensor 91031 you will get the part description etc.
Search online using the required part number to find suppliers that suit you best e.g. this supplier is cheaper than Sears (although shipping may be a factor to be aware of depending on your location)
por
I put a new starter solenoid on my john deere riding when i hooked the wires up to it i put the fuse back in it tried to start without the key what did i hook wrong.
Pontuação 0
I have a countax c400h and I have changed the solenoid 3 times and just get a single click when I turn the key ? Have I wired something wrong ?
Pontuação 0
1 dos comentários:
I get 13 v through the positive battery lead
por
Adicionar a sua resposta
john será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 68
Últimos 7 dias: 339
Últimos 30 dias: 1,278
Duração total: 66,464
