Ir para o conteúdo principal
Broken backlight from logic board cause
During a screen repair I didnt disconnect the battery and when i connected the home button connector to the logic board a small amount of smoke came out. I had the board microsoldered and repaired but I am wondering now what the cause was? Was the replacement screen faulty or was it just because the battery wasnt disconnected as id like to know if i could still use the replacement screen or if it needs binned.
Thanks.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
I think the obvious answer here is to get in touch with the repair shop and ask them what they did and why.
Now, in general, the iPhone 6S backlight circuit is very sensitive when the battery is plugged in and you mess around with the screen connections. A short occurs and one or several components get toasted. It can be just the filter but it can also affect the rest of the backlight circuit (diode, coil, driver) and connector.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
1. In future always disconnect battere when do anything in iPhone 6s
2. Try different screen
Pontuação 1
Adicionar a sua resposta
rossj456 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 387
