Ir para o conteúdo principal
Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Repair damage- help identify part needed
Have an iPad mini retina att model, while removing the digitizer for a repair a cable going to the cell antena area was severed, can someone help me identify the part needed as well as a reputable source ? See link for image https://drive.google.com/open?id=0B8JUkQ...
Update (04/12/2017)
Sorry about that, tried to post from a mobile and was unable to add a photo here is the photo, thanks for the help.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Nicholas, you'll have to clear your link "You need permission" if you want anyone to look at it. You should consider posting your images with your question by using this guide Adicionar imagens a uma pergunta já existente
por
Repost you picture using something different so we can give your a proper answer. Thanks
por
Adicionar um comentário
1 resposta
Solução escolhida
That is the upper right antenna. You can find it here.
Follow this guide(the antenna is specifically addressed on steps 71-73)
Imagem de Replace a right cellular antenna compatible with the model A1454, A1455, A1490 1st or 2nd generation iPad mini tablet.
Produto
iPad mini & mini 2 Right Cellular Antenna
$19.99
Esta resposta foi útil?
Pontuação 3
1 comentário:
Thanks for the quick answer and part source !
por
Adicionar a sua resposta
Nicholas será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 16
Ao todo: 169
