Ir para o conteúdo principal
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
How can I remove a CD stuck in the CD drive
A cd was already in the cd drive and another cd was put in the same cd drive how can i remove them
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Solução escolhida
Step 1 (if you are truly lucky): Boot up while holding down the trackpad button to eject the CDs.
Step 2: Access the drive itself, remove the cover, and remove the CDs.
Good luck!
Esta resposta foi útil?
Pontuação 3
I have had this problem with a CD with a stick-on label. Answer:stick your finger nail into the CD slot and pry the case up gently at the same time you hit the "eject" button or command- E. Works for me!
Pontuação 2
Adicionar a sua resposta
Gary Chisolm será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 4,144
