Ir para o conteúdo principal
The Coolpix S7000 was released in 2015. The camera has 20x wide optical zoom, Wi-Fi capabilities, and Near-Field-Communications (NFC).
Black screen when camera is turned on.
I had taken several pictures and all was well and turned the camera off. When I turn the camera on again I had nothing but a blank / black screen. I can see the different camera setting, flash, macro, ets. but no image on the screen of what the camera is facing. I have gone through all the different setting in "menu" and changed to all of the different setting on the image wheel with no positive results. I'm out of ideas, any assistance would be greatly appreciated as I really enjoy the features of this camera. Thank you.
Esta é uma boa pergunta?
Pontuação 4
1 comentário
Hah, had the problem on my p1000 and fixed it with your technique! Thanks.
por
Adicionar um comentário
3 respostas
Solução escolhida
Hi @xtremecacher ,
As you can see the various menus this proves that the LCD screen is working.
Try taking a few pictures, (I realize that you cannot 'see' what you are taking) and then download them to a computer to see if there is any pictures at all or just black pictures.
If only black pictures then the problem could be a faulty CCD sensor in the camera
Esta resposta foi útil?
Pontuação 6
1 comentário:
yup!
a couple smacks into my other hand on the camera's side
bug thanks to thee
[s3300 user right here, buuddy]
por
I had the same problem with my S7000. I tried the above check and got black pictures. I know it's not a quality fix, but I took the camera in one hand and slapped it into the other hand a few times. I was hoping to jiggle any loose electrical connections into making contact. Well it worked and the camera has been working again for 2 weeks now. I don't know how long the fix will last or if it will quit working again the next time I bump it. I loved the pictures it could take with the large optical zoom, and I didn't wanted to go out and buy another one without at least trying to get it working. Good luck.
Pontuação 4
7 comentários:
Omg the slap worked in all my time never would i have guessed but thank you lol
por
After slapping my B500 a few times, (Sorry love), I changed the card & VOILA!!
por
Coolpix S3300. Had the same problem! It took a few good bashes on a mouse mat but now working!
por
well i am not sure if it was the slap or the fact that i emptied my sd card but either way its working now so thanks
por
This thread is great. I had the same problem (black screen upon powering on). Banged the camera in my hands and a few times on the desk top and voila! The camera now functions perfectly. Thanks!!!
por
Exibir mais 2 comentários
So I tried banging it and clearing the memory card which didn't work for me. The thing that did solve my problem was to clean out the cable ports inside the waterproof battery/card chamber.
After reading the manual I realised that when a cable is plugged in to display your photos on a TV, the screen goes black. So I cleaned the cable ports with a toothpick and it solved the problem. Something must have got in there and closed a circuit making the camera think it was plugged into a tv. Hope this helps someone!
Pontuação 1
1 comentário:
I triend banging the camera, clearing my sd card even cleaning the cableports with the toothpick and nothing worked.. i think i need to get it to service
por
Adicionar a sua resposta
John adams será eternamente grato(a).
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 57
Últimos 30 dias: 161
Ao todo: 45,060
