Ir para o conteúdo principal
The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
Broke LT and RT holders how do I replace it?
I have provided two pictures, the blue controller is the one that I'm trying to fix. The dissasembled controller is the one I'm using for the RT and LT.
I want to remove the Trigger holder from the controller but don't know how to do it.
It's the metal piece holding the Triggers.
I need help guys.
Esta é uma boa pergunta?
Pontuação 3
1 comentário
Hello, my RT button on my Xbox One controller is not working correctly. When I get on NFS the car drives by its self.
por
Adicionar um comentário
6 respostas
Pergunta mais útil
https://www.youtube.com/watch?v=NZp8Rcik...
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thanks for that
por
Hello @imzai,
There is no photos as I can see, did they upload correctly?
Well, I provided a few IFixIt links that may help
Xbox One Wireless Controller Trigger Rumble Motor Replacement
Xbox One Wireless Controller Buttons Replacement
I hope these help!
Thanks,
Keegan
Imagem de Xbox One Wireless Controller Model 1537 Trigger Rumble Motors
Guia
Nível de dificuldade:
Difícil
15 - 20 minutes
Imagem de Xbox One Wireless Controller Model 1537 Buttons
Guia
Difícil
30 minutes - 1 hour
Pontuação 1
3 comentários:
I have edited my post, I've uploaded the pictures, what I mean to to remove from dissasembled controller is the metal stick holding the triggers.
por
Okay I see, so if you look back in to the link Xbox One Wireless Controller Trigger Rumble Motor Replacement it shows how to remove the moters. So, I think by the look of the photos its soldered to the board. Can you confirm this?
por
You have to press the small part of the metall pin then it comes out on the other side where you can grab it with pliers / tongs / nippers and pull it out gently.
You have to be very carefull, else you destroy the trigger or the frame.
Pontuação 0
I need a LT trigger spring
Pontuação 0
How to take this off lt button
Pontuação 0
1 comentário:
Same here, my rigger holder is broken too
por
My left triggers has came out of the socket please help
Pontuação 0
Adicionar a sua resposta
J Angel será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 67
Ao todo: 30,438
