Ir para o conteúdo principal
Xbox One Wireless Controller Buttons Replacement
O que você precisa
  1. Xbox One Wireless Controller Buttons Replacement, Battery Pack: passo 1, imagem 1 %32
    • Remove the battery pack cover.
    • Remove batteries.
    Pergunte ao FixBot
    Comentar
  2. Xbox One Wireless Controller Buttons Replacement, Side Handles: passo 2, imagem 1 %32 Xbox One Wireless Controller Buttons Replacement, Side Handles: passo 2, imagem 2 %32
    • We recommend using a nylon spudger for this step. A metal spudger is shown.
    • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
    Pergunte ao FixBot
    Comentar
  3. Xbox One Wireless Controller Buttons Replacement, Screws: passo 3, imagem 1 %32 Xbox One Wireless Controller Buttons Replacement, Screws: passo 3, imagem 2 %32
    • There is a hidden screw located in the middle of the controller behind the label.
    • Use a screwdriver and punch a hole directly in the center of the label.
    • You may also lift the label if you do not want to puncture it.
    • Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Xbox One Wireless Controller Buttons Replacement, Backplate: passo 4, imagem 1 %32
    • Remove the backplate.
    Pergunte ao FixBot
    Comentar
  5. Xbox One Wireless Controller Buttons Replacement, Faceplate: passo 5, imagem 1 %32
    • Remove the faceplate.
    Pergunte ao FixBot
    Comentar
  6. Xbox One Wireless Controller Buttons Replacement, Top Motherboard: passo 6, imagem 1 %32 Xbox One Wireless Controller Buttons Replacement, Top Motherboard: passo 6, imagem 2 %32
    • You may let the rumble motors hang freely out of their sockets.
    • De-solder the soldered joints while holding the red and black wires down on the top motherboard.
    • De-solder the black and gray wires that are attached to the top motherboard.
    • Remove the rumble motors and set them aside.
    • Be careful while using the soldering iron not to damage other components or hurt yourself.
    • For information on how to solder, click here.
    Pergunte ao FixBot
    Comentar
  7. Xbox One Wireless Controller Buttons Replacement: passo 7, imagem 1 %32
    • Unscrew the two 7mm T6 screws located near the rumble motor sockets.
    Pergunte ao FixBot
    Comentar
  8. Xbox One Wireless Controller Buttons Replacement: passo 8, imagem 1 %32
    • Firmly grip sides of motherboard near the middle.
    • Lift upwards while slightly wiggling the motherboard forward and backward.
    • Lifting the motherboard will require some force.
    Pergunte ao FixBot
    Comentar
  9. Xbox One Wireless Controller Buttons Replacement, Bottom Motherboard: passo 9, imagem 1 %32 Xbox One Wireless Controller Buttons Replacement, Bottom Motherboard: passo 9, imagem 2 %32
    • Remove the six T6 Torx screws located on the bottom motherboard.
    Pergunte ao FixBot
    Comentar
  10. Xbox One Wireless Controller Buttons Replacement: passo 10, imagem 1 %32 Xbox One Wireless Controller Buttons Replacement: passo 10, imagem 2 %32
    • Remove the bumpers by prying them off of the pegs that secure them, using a spudger. They are located on the front and back of the controller.
    • A standard nylon spudger is recommended for this step. Using a metal spudger near the motherboard as shown risks damaging your device.
    Pergunte ao FixBot
    Comentar
  11. Xbox One Wireless Controller Buttons Replacement: passo 11, imagem 1 %32 Xbox One Wireless Controller Buttons Replacement: passo 11, imagem 2 %32
    • Lift the piece surrounding the Home button off of its pegs.
    • Pry it off of the other side, using a spudger on the pins.
    • Removing this piece may require a lot of force.
    Pergunte ao FixBot
    Comentar
  12. Xbox One Wireless Controller Buttons Replacement: passo 12, imagem 1 %32
    • Remove the bottom motherboard.
    Pergunte ao FixBot
    Comentar
  13. Xbox One Wireless Controller Buttons Replacement, Buttons: passo 13, imagem 1 %32
    • Remove the rubber backing to the buttons.
    Pergunte ao FixBot
    Comentar
  14. Xbox One Wireless Controller Buttons Replacement: passo 14, imagem 1 %32
    • With the buttons facing down, push them up out of their housings, and remove.
    Pergunte ao FixBot
    Comentar
Conclusão
110 outras pessoas executaram este guia.
Garrett George
Membro desde: 01/22/15
6.482 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 20-15, Maness Winter 2015 Membro de Cal Poly, Team 20-15, Maness Winter 2015
CPSU-MANESS-W15S20G15
5 Membros
Autoria de 54 guias
32Comentários do guia
do you have a URL for the repair parts (rubber pads) ect. for the wireless controllers
kendixon69 - Responder Compartilhar
For all of my Xbox One controllers, I needed the tamper-resistant Torx bits. They're the ones with the hole in the center, like these: http://www.amazon.com/Pro-Grade-13pc-Tam.... Any tamper-resistant or Torx security bit set should do as long as it has the sizes listed in the Tools section of this FixIt article.
Frank Wilson - Responder Compartilhar
Just an FYI you can use a flat screwdriver against the post and side and it will either work or break the post which is what happened to me and allowed me to use a normal torx screwdriver.
sid f - Responder Compartilhar
Looking to replace the switch on the right bumper, can't find any parts or numbers. Looking for help please.
Comentar
Visualizações:
Últimas 24 horas: 34
Últimos 7 dias: 147
Últimos 30 dias: 692
Ao todo: 580,852
