Ir para o conteúdo principal
Xbox One Wireless Controller Trigger Rumble Motor Replacement
O que você precisa
  1. Xbox One Wireless Controller Trigger Rumble Motor Replacement, Battery Pack: passo 1, imagem 1 %32
    • Remove the battery pack cover.
    • Remove batteries.
    Pergunte ao FixBot
    Comentar
  2. Xbox One Wireless Controller Trigger Rumble Motor Replacement, Side Handles: passo 2, imagem 1 %32 Xbox One Wireless Controller Trigger Rumble Motor Replacement, Side Handles: passo 2, imagem 2 %32
    • We recommend using a nylon spudger for this step. A metal spudger is shown.
    • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
    Pergunte ao FixBot
    Comentar
  3. Xbox One Wireless Controller Trigger Rumble Motor Replacement, Screws: passo 3, imagem 1 %32 Xbox One Wireless Controller Trigger Rumble Motor Replacement, Screws: passo 3, imagem 2 %32
    • There is a hidden screw located in the middle of the controller behind the label.
    • Use a screwdriver and punch a hole directly in the center of the label.
    • You may also lift the label if you do not want to puncture it.
    • Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Xbox One Wireless Controller Trigger Rumble Motor Replacement, Backplate: passo 4, imagem 1 %32
    • Remove the backplate.
    Pergunte ao FixBot
    Comentar
  5. Xbox One Wireless Controller Trigger Rumble Motor Replacement, Faceplate: passo 5, imagem 1 %32
    • Remove the faceplate.
    Pergunte ao FixBot
    Comentar
  6. Xbox One Wireless Controller Trigger Rumble Motor Replacement, Top Motherboard: passo 6, imagem 1 %32 Xbox One Wireless Controller Trigger Rumble Motor Replacement, Top Motherboard: passo 6, imagem 2 %32
    • You may let the rumble motors hang freely out of their sockets.
    • De-solder the soldered joints while holding the red and black wires down on the top motherboard.
    • De-solder the black and gray wires that are attached to the top motherboard.
    • Remove the rumble motors and set them aside.
    • Be careful while using the soldering iron not to damage other components or hurt yourself.
    • For information on how to solder, click here.
    Pergunte ao FixBot
    Comentar
  7. Xbox One Wireless Controller Trigger Rumble Motor Replacement: passo 7, imagem 1 %32
    • Unscrew the two 7mm T6 screws located near the rumble motor sockets.
    Pergunte ao FixBot
    Comentar
  8. Xbox One Wireless Controller Trigger Rumble Motor Replacement: passo 8, imagem 1 %32
    • Firmly grip sides of motherboard near the middle.
    • Lift upwards while slightly wiggling the motherboard forward and backward.
    • Lifting the motherboard will require some force.
    Pergunte ao FixBot
    Comentar
  9. Xbox One Wireless Controller Trigger Rumble Motor Replacement, Trigger Rumble Motors: passo 9, imagem 1 %32
    • Remove the yellow tape holding the wires in place on the front of the controller.
    Pergunte ao FixBot
    Comentar
  10. Xbox One Wireless Controller Trigger Rumble Motor Replacement: passo 10, imagem 1 %32 Xbox One Wireless Controller Trigger Rumble Motor Replacement: passo 10, imagem 2 %32 Xbox One Wireless Controller Trigger Rumble Motor Replacement: passo 10, imagem 3 %32
    • Unscrew the two 7mm T6 Hex screws located on underside the triggers.
    Pergunte ao FixBot
    Comentar
  11. Xbox One Wireless Controller Trigger Rumble Motor Replacement: passo 11, imagem 1 %32
    • Remove the trigger covers.
    Pergunte ao FixBot
    Comentar
  12. Xbox One Wireless Controller Trigger Rumble Motor Replacement: passo 12, imagem 1 %32
    • Desolder the wires from the motherboard.
    • Remove the rumble motors from its socket and pull the wire with it.
    Pergunte ao FixBot
    Comentar
Conclusão
20 outras pessoas executaram este guia.
Tommy
Membro desde: 01/22/15
2.011 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 20-15, Maness Winter 2015 Membro de Cal Poly, Team 20-15, Maness Winter 2015
CPSU-MANESS-W15S20G15
5 Membros
Autoria de 54 guias
10Comentários do guia
After a drop onto tile flooring, the side clip of the outer handle snapped and got lodged into the trigger, causing it to only pull to 80% and go no further. Thanks for this breakdown.
solofrom303 - Responder Compartilhar
My right trigger won't work on gta 5 and on other games it works
Devean Velasquez - Responder Compartilhar
Very strange, Devean. That sounds more like a software problem than a hardware problem, if I had to guess. If you haven't already, maybe check to make sure that your control setup is correct.
Alternatively, see if you can find any other games that your RT doesn't work for, and see what they have in common with GTA - it might be that the trigger isn't registering as fully depressed, or only ever registering when fully depressed.
Liam Gow - Responder Compartilhar
Trying to replace bumpers assembly and green sync button fell out can not figure how to put it back in.
Anthony Bembenek - Responder Compartilhar
Do you know how to remove the plastic plate where the trigger rumble sits?
Angel Marban - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 40
Últimos 30 dias: 236
Ao todo: 66,969
