Space bar not working
My space bar didn't work so I replaced the keyboard and it still doesn't work. Any suggestions?
Esta é uma boa pergunta?
Hey,
There is a possibility when you replaces the KeyBoard it was a malfunctioning KeyBoard. Its rare, but it happens.
I would say use a USB Keyboard and see if the spacebar works on that. and if it does, its just the keyboard. If it doesnt then it is most likely a software issue. and we can work form there.
Replacement Guide: Toshiba Satellite L675D-S7016 Keyboard Replacement
Thanks.
Keegan
Esta resposta foi útil?
I took it into a local repair shop and they found out that it was a driver conflict that was causing the problems.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 1,066
Hi,
Just curious. Try using a USB keyboard and see if that works OK.
That way will prove it is either a hardware or a software problem
por jayeff
