How to replace broken glass front
Could you please tell me the part no. and how to replace the glass screen on an Apple 24" LED display.
Esta é uma boa pergunta?
I believe that this is the info you are looking for
Part Name: Cinema Display 24" Glass Replacement
Apple Part #: 922-8678
available here http://www.macpartsonline.com/922-8678-p... and here
http://www.welovemacs.com/9228678.html and here is the service manual.http://tim.id.au/laptops/apple/displays/... hope this helps to get your monitor fixed. Good luck....
Esta resposta foi útil?
Many thanks for your help. Do you happen to know of a supplier in the UK or Europe. I have tried searching for the part no. with no luck.
David I sure don,t, but I know that there are plenty of people from the UK and Europe on here and hopefully some of our European friends can help you out with this. But you could try http://www.thebookyard.com/index.php or http://www.applemacparts.co.uk/store/ind... and see if they can help you find what you are looking for. Good luck
Again many thanks for your help. Much appreciated.
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 8,352
