Ir para o conteúdo principal
Motor 2.3L 4 cilindros ou 3.0L V6, 6ª geração
Why is my D4 light flashing
Hello, my name is Dennis O'Malley. I was hoping you could answer my question about my 02" Accord. Now I dont know why but my check engine light came on and then my D4 light started flashing then it caused my car to start running funny and was hoping you could explain.
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Pergunta mais útil
The D4 light flashing means the engine computer detected a transmission problem. Stop by a parts store like autozone and have them read the codes. You should end up with a code that starts with a "P" and this particular model year had a TCM issue
Esta resposta foi útil?
Pontuação 2
2 comentários:
How do you fix it
por
@williamjoh79086 depends on what the code shows
por
check the shift solenoid
Pontuação 0
1 comentário:
Same problem ,,but how do u check solenoid,
por
Adicionar a sua resposta
Dennis O'Malley será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 18
Ao todo: 7,556
