Ir para o conteúdo principal
Repair guides and support for HP's LaserJet Laser Printer Line, which includes printers with model numbers starting with LaserJet, LaserJet Pro, Color LaserJet, P, M, CP, and CM.
HP P1005 LaserJet printing with streaks on paper, Cleaning?
This printer was relatively inexpensive and is great for documents in Black & White. Quick, efficient and cheap to operate.
How do I disassemble it to clean the mechanics to get a cleaner printout ?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
You could try to clean the print-cartridge area as well as to clean the device paper path if you are experiencing toner specks or dots on the printouts. you might also try to clean the pickup roller. the users manual describes all those steps in detail and is available at http://www.retrevo.com/samples/HP-Printe... as well as http://h10025.www1.hp.com/ewfrf/wc/manua... Good Luck
Esta resposta foi útil?
Pontuação 2
2 comentários:
Dead links live links are needed to access user manuals.
por
Hi @ dave.trotsky.ireland
Here's a link to the User manual for the P1000 series printer taken from this webpage
por
Adicionar a sua resposta
capone99 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 12
Ao todo: 6,618
