Ir para o conteúdo principal
Número do modelo NX785QC8G, lançado em 2014. Processador Quad core ARM Cortex A9/1,6 GHz, 1 GB de RAM DDR.
Tablet shuts down while playing games
Tablet shuts down while playing games. Tablet also will not open games app. - just closes automatically. Comes up with a box that says Thermal Shutdown. Thermal critical error occurred.
Esta é uma boa pergunta?
Pontuação 3
3 comentários
How do I fix this problem
por
Check the chosen answer for what you’re looking for.
por
how do i fix this on amazon kindle fire gen. 5
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Your tablet is overheating.
If your tablet is in case, try taking it out. I have the same tablet and it tends to get hot and shut down.
Also, try some type of cooling pad or something that will allow air to get to the underside . That should help remove any build up of heat around it.
If it is heating up right after starting up, then you may have some internal problems. You might want to look into having someone look at it or finding a new tablet.
Good luck.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Brenda Fulton será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 27
Ao todo: 1,143
