Ir para o conteúdo principal
Anunciado em 16 de outubro de 2014, identificável pelo número de modelo A1347 e EMC 2840.
Adding SSD Drive to PCIe model
Can anyone assist with what parts I would need to add an SSD to a Mac Mini 2014 that came with a PCIe 512 GB drive?
I'd like to make it a dual drive setup, but can't confirm what part is needed to do so. Any help would be greatly appreciated.
Esta é uma boa pergunta?
Pontuação 3
2 comentários
me to i would like to recieve and so place a PCIE drive on my mac mini late 2014. can you send me the link for buying that item?
bst regards
por Compartilhar
@yannick17 - Review my answer for the details
por Compartilhar
Adicionar um comentário
2 respostas
Solução escolhida
If you already have the PCIe SSD then you're adding a SATA drive (either a HD or a SSD) You'll need the to follow this IFIXIT guide Substituição do cabo do disco rígido do Mac mini final de 2014 and need this part & tool kit: Mac mini Dual Drive Kit. Be careful here! The size of the drive needs to physically fit (12 mm is about it).
If you have a SATA HD already then you'll want this: either the drive carrier with the SSD cable mounted Hard Drive Carrier w/ SSD Flex Cable - Apple P/N 076-00040 or the cable its self Cable, SSD Flex - Apple P/N 076-00018
Here's the IFIXIT guides:
Imagem de All the hardware needed to a second hard drive to your 2011 or 2012 Mac mini.
Produto
$29.99
Imagem de Mac mini Late 2014 Cabo do SSD PCIe
Guia
Substituição do cabo do SSD PCIe do Mac mini de final de 2014
Nível de dificuldade:
Moderado
15 - 20 minutes
Imagem de Mac mini Late 2014 Cabo do disco rígido
Guia
Moderado
1 hour
Imagem de Mac mini Late 2014 Bandeja do disco rígido
Guia
Substituição da bandeja do disco rígido do Mac mini de final de 2014
Moderado
Esta resposta foi útil?
Pontuação 1
2 comentários:
Dan, If I already have a fusion drive in there will I need any of these replacement parts, or can I just substitute the respective PCIe and 2.5 inch drives for the existing ones?
por Compartilhar
You'll need to make a full backup before doing anything.
First step is to break the Fusion Drive following this How to split up a Fusion Drive.
And yes, all of the needed hardware sans the replacement drive/s is present.
But before you jump what is your goals here?
por Compartilhar
When adding a HDD to a PCIe SSD only 2014 mini, which HDD cable do you need? (1) the mini dual drive cable, or (2) the upper SATA cable?
Pontuação 0
1 comentário:
Adicionar a sua resposta
tomtcs será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 35
Ao todo: 2,016
