Ir para o conteúdo principal
Lançado na América do Norte em novembro de 2006, o Wii foi o primeiro console de jogo da Nintendo a oferecer suporte direto à conectividade com a internet, permitindo tanto jogos online quanto a distribuição digital de jogos e aplicativos de mídia através do Wii Shop Channel.
Controller will not sync with Wii
Does anyone know what the problem might be?
Esta é uma boa pergunta?
Pontuação 49
9 comentários
Who would of thought it was that easy! Thanks!
por Compartilhar
I was so happy! I my threw hands in the air, whisper shouting yes. I thought it was because I also have a Wii U.
por Compartilhar
How do I sync my controller ? I did all the steps and no lights come on on my control. I have new batteries in too. Several sets. Please help.
por Compartilhar
Same here. I couldn't get mine to work either but I have the Rock Candy remotes for an original Wii because I bought it used and no remotes came with it.
por Compartilhar
Worked a treat when I followed instructions. Thank you. 3/1/2018 SeaVixen man
por Compartilhar
Exibir mais 4 comentários
Adicionar um comentário
8 respostas
Solução escolhida
Have you tried to resync it. I found this
1. Press the Power button on the Wii console to turn it on.
2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and open the SD Card Slot cover on the front of the Wii console. (The SD Card Slot is the small door located near the disc drive slot.)
3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
Esta resposta foi útil?
Pontuação 70
55 comentários:
Or you could try this. Connect by pressing the red button on your wii remote. It should start flashing for about 30 secs or so. Then, while its flashing, press the red button on your wii console, open the flap under the reset button to find it. once you have done that continously press 1 and 2 at THE SAME TIME 10 times then press power button on top left of remote, press the A button and that could make it work. For further info http://www.nintendo.com/consumer/systems... good luck
por Compartilhar
Worked perfectly when I tried to sync my rock candy remote to my Wii. Thank you!
por Compartilhar
Yessssssss it works gee wiz thank you so much...we were trying for a while!
por Compartilhar
i have tried all the steps on the first comment but still unable to make it work. Any help would be appreciated. Thanks
por Compartilhar
It didn't work i did everything and still doesn't work.
por Compartilhar
Exibir mais 50 comentários
Try unplugging your Wii console from the power cord for a few minutes. Then plug the power back up turn on the Wii. Now follow the normal steps to sync your remote. (Push the red button on the remote then the red button on the Wii). This worked for me the first time I tryed it. Don't ask why cause I have no idea.
Pontuação 22
12 comentários:
Brilliant! This worked for us. Thanks
por Compartilhar
It worked when I was syncing my rock candy remote
por Compartilhar
This worked great!!!
por Compartilhar
Omg thank you so much I did everything then I saw your and did it thanks so much
por Compartilhar
Thanks so much! Now I can watch Netflix again! :D
por Compartilhar
Exibir mais 7 comentários
Turn on wii. Press A to main wii menu (with another working remote). If no remote is yet synced wii should prompt you to do so at this point, either way continue to next step.
Press and hold red sync button (inside little door under power button) for 3 seconds.
Then press red sync button on the remote (under battery door). lights will flash and one will stay lit to show you which player that remote has become.
**You can sync your remotes to other game consoles, however each time you change consoles that you are playing you will need to re sync your remote. ( not all remotes just the ones played on another console)
Happy gaming. -B
Pontuação 10
9 comentários:
Thanks Bridget,it worked
por Compartilhar
Thank you. That worked !
por Compartilhar
This is the method to sync the remote to the device.....if you do this and it doesn't work then follow method from above comment, which is to unplug the power cord from the console for a few minutes then plug it back in and try to sync again...
por Compartilhar
Thank you so very much. I followed the suggestions of others and nothing worked. Now we have 4 working controllers for Family Game Night. Thanks again.
por Compartilhar
Does the sd card have to be in there?
por Compartilhar
Go to home menu,wii remote settings,Reconnect press 1 and 2 rapidly hope this works -Crazychicken
Pontuação 1
1 comentário:
This only see works if controller won't connect when already synced.
por Compartilhar
You can also use a screen cleaning cleaner and a cloth to clean the remote sensor bar that is mounted atop your TV.
Pontuação 1
Replace the Bluetooth module. See Youtube videos for instruction.
I had two units non working Wii, one won't sync no matter what procedure I followed. It was a hardware problem which got fixed by replacing the Bluetooth board I bought from Ebay.
I also had another Wii that had a blank display. This was also fixed by replacing the Bluetooth module.
If the other procedures don't work, try this hardware fix.
Pontuação 0
My Wii Remote had automatically de-synced after lying around for 1/2 year (with dead batteries inside) and I could not get it to re-sync. Neither the red sync button nor the “add remotes” in the home button menu worked. New batteries did not help.
What fixed it:
I removed the batteries for 3+ minutes, then re-synced the Wii Remote with the red sync button while in System Menu.
Pontuação 0
I only had a third party Wiimote which I gave fresh batteries and would have flashing LEDs as if trying to pair but none of the usual methods worked. Finally got it working after unplugging the Wii for 10 seconds, removing the batteries from the remote, turning the Wii back on and pressing the sync button then shortly after putting the batteries back in the remote and it instantly paired. I think it's the ordering that's important here.
Pontuação 0
Adicionar a sua resposta
cyberworldzero será eternamente grato(a).
Visualizações:
Últimas 24 horas: 18
Últimos 7 dias: 171
Últimos 30 dias: 645
Ao todo: 578,139
