Ir para o conteúdo principal
A Sharp EL-531X é uma calculadora científica produzida pela Sharp.
How can I fix it?
MY calculator won't turn off except after being left alone for a long period of time and the buttons aren't responding. Also it only displays 0=. and I've even tried restarting it many times.
Esta é uma boa pergunta?
Pontuação 2
1 comentário
The calculator will display 1 no matter with the battery or not.
It stop working.
por Compartilhar
Adicionar um comentário
2 respostas
Solução escolhida
Hi,
Try replacing the battery and then resetting the calculator.
The EL-531X uses a LR-44 (or equivalent) battery
Here are two images that show what to do.
Battery Replacement
Imagem
Reset
Imagem
(click on images to enlarge for better viewing)
Esta resposta foi útil?
Pontuação 2
1 comentário:
Hi. After changing battery and resetting, all the buttons still didn't work. Please help.
por Compartilhar
I had the same problem and managed to fix it by removing the battery and unscrewing and removing the back cover. That's it. I reckon that the issue happened because the "=" key connection was stuck, so uncovering the calculator might have "released" the connection. Hope this helps!
Pontuação 0
Adicionar a sua resposta
fahimakhan2 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 42
Ao todo: 5,354
