Ir para o conteúdo principal
Um celular slider tipo barra produzido pela Sony Ericsson em colaboração com a Walkman, lançado em 2009.
2G coverage is disappearing
Dear Support,
we have Sony Ericsson W995. when we make a call the 2G coverage is going off while if we force the phone to 3G it will work normally.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hi @ikhalil ,
Check your mobile phone service provider's coverage map to see where 2G is located. (go to their website to find it).
A lot of providers are disconnecting 2G to use the frequency for 4G. Depending on your country of course.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Hi @jayeff
it is not a service provider problem. it is a phone problem. Am GSM engineer and this phone is used for test and it is the only phone that cause such problems for this problem am sure it is phone problem
por
Hi @ikhalil ,
Did you try changing the SIM card, just to eliminate it as a possibility?
por
Adicionar a sua resposta
Ibrahim será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 474
