Ir para o conteúdo principal
Guias de reparo para máquinas projetadas para se mover lentamente e realizar grandes tarefas, incluindo veículos agrícolas e de construção destinados a funções especializadas.
I have no throttle control
so I recently had to replace the governor on my Ford 8N as the housing was badly damaged I purchased an after market one and installed it went on no problems (btw this is a gear driven one not a belt driven). after getting it back together my throttle rod from gov to throt control was short and broke when I tried to adjust. I purchased a replacement and installed no problem bot now for some reason when I start the tractor and I adjust the hand throttle the tractor run either at slightly above idle or wide open with no in between and only having moved throt lever 2-3 notches on quadrant. i would also like to say the tractor ran fine before gov replacement and also runs fine other then lack of throttle control
Esta é uma boa pergunta?
Pontuação 2
4 comentários
@sideshowbo12 just to clarify, you did check the linkage to ensure it is properly installed?
por
We have a diesel tractor with Roosa Master fuel pump with electric shut of and we replaced the solenoid in the pump and the throttle is not responding do u have a solution?
por
danieljohnsweeney106 give us more information about the tractor and/or the engine. Make , model etc. all will help.
por
My IH 404 was like that. It was the pin connecting the govenor control arm to carburator was rusted frozen.
por
Adicionar um comentário
1 resposta
Solução escolhida
@sideshowbo12 see if the adjustment will make a difference
OVERHAUL. Remove governor from engine. Remove flyball unit, shaft and driven gear assembly (Fig. FO-32) from governor body after removing base screw. Remove spring clip and disassemble shaft and flyball parts. Examine balls and renew if they have flat spots, pits or are excessively worn. Inner surface of cone shaped upper race should be smooth and even. If grooved or pitted, renew race. Check condition of fork base and thrust bearing, drive shaft bearing and driven gear. Renew worn or damaged parts and reassemble unit.
Clearance between washer and fork base should be from .220 to .230 and is adjusted by varying the number of shims (18241) until clearance is correct. If available, Governor Setting Gauge No. ELO7691 shown in Fig. FO-33 may be used to check adjustments. To check clearance between washer and fork base, clamp shaft and driver assembly in Gauge as shown, and insert Go-No Go gauge between washer and fork base. If only thin end of gauge can be inserted, clearance is satisfactory. Insertion of gauge all the way on thick section indicates excessive clearance and thin shims should be added until clearance is correct.
Check governor lever shaft assembly and needle bearing (Fig. FO34) for binding or excessive looseness and renew parts where required. If inner lever assembly is loose, install new parts or insert a 1/2 x 2-7/8 inch shim as shown in Fig. FO35. Check governor shaft bushing for wear and if necessary renew bushing, using suitable removing and reinstalling tools as shown in Fig. FO38. CAUTION: Make sure that thrust washer shown in Fig. FO32 is in place before installing bushing.
Check governor arm adjustment, using Governor Setting Gauge as shown in Fig. FO36. Clamp housing in gauge as shown and hold governor outer lever in wide open position. Insert Go-No Go gauge as shown and if only first step of gauge can be inserted, clearance is satisfactory. If not correct, unclamp housing, lay governor arm across flats on fixture and strike governor arm lightly as shown in Fig. FO37. Reclamp governor and again check clearance after bending arm. Reassemble governor and install on engine.
Imagem
Esta resposta foi útil?
Pontuação 5
Adicionar a sua resposta
Joe será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 20
Ao todo: 5,900
