Ir para o conteúdo principal
Smartphone LG Treasure Número do modelo: LGL52VL Data de lançamento: Abril de 2016
How do I direct dial?
I belong to our fire dept. and I need to direct dial to Iamresponding.com to respond to a call. How do I set it up? Any help would be appreciated. Thank You!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
When you say "I need to direct dial to Iamresponding.com to respond to a call", I'm assuming you mean this:
"Here's how it works: After receiving a dispatch notification through any existing dispatch system, responders either press one button on IamResponding's free apps, or speed dial a pre-programmed toll-free number on any phone. This whole process takes mere seconds, at most" (see http://www.iamresponding.com/v3/Pages/Le...).
So you can either download the Android app from the Google Play store and follow these directions for using the app from IamResponding: http://www.iamresponding.com/v3/articles...
Or you can set up speed dial to IamResponding's toll-free number using this guide: http://webcazine.com/13405/android-5-0-l...
If this isn't what you meant by "direct dial" please let me know.
Esta resposta foi útil?
Pontuação 1
4 comentários:
My LG Treasure has a direct dial widget on the phone. I'm wondering how to use it?
por Compartilhar
https://www.straighttalk.com/wps/wcm/con...
Look at page 62. This is for a different LG phone, but I couldn't find anything on the Treasure and direct dialing. Hopefully, the process is the same.
por Compartilhar
Thank You Tim! It worked!
por Compartilhar
Good to hear. Feel free to accept my answer to close out your question.
por Compartilhar
Adicionar a sua resposta
kb2khr será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Ao todo: 616
