Ir para o conteúdo principal
Screen is black after replacement and..
So , we tried to replace the iphone screen because its very cracked. At first it turned on but looked glitchy but the touch screen didnt want to register. After that it just wouldn't turn on. We checked everything and nothing was damaged. Put the old screen back on but no dice, still nothing. I have it plugged into the computer and ive tried hard rests and dfu. Itunes recognizes the device and i'm doing a reset/ restore but it still won't turn on. Was it broken somehow while trying to switch screens? how come it worked and then suddenly worse off without doing anything?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Did you unplug or plug in the screen while the battery was connected?
por
Adicionar um comentário
1 resposta
Solução escolhida
As Ben suggested, not disconnecting the battery first can cause the backlight circuit to fail. Seeing as how both your original and replacement screen do not work, the problems seems to be on the logic board.
Do what you normally would to "turn on" your phone. The check your display with a flashlight. If you can see a very dim image on your screen, then it is the backlight circuit. This will require a micro-soldering repair.
Esta resposta foi útil?
Pontuação 3
2 comentários:
can i do the micro soldering on my own? how? thank you
por
also there is no dim image when i turn it on its just black, no display, nothing what should i do?
por
Adicionar a sua resposta
iloveanimebye será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 158
