Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
Replaced front screen .
My cousin gave me her old iPhone 5s but the screen was broken and dangling by the connector cables BUT half of the screen was still visible and the full screen reacted when you touch it now I have bought a new screen replaced it transferred my camera ,homebutton, shield, etc. I watched a video and followed every step twice but my phone still will not power on I tried to charge it.. no vibration please help!!!
Update (01/26/2017)
Thank you guys for the answers but I tried again to charge it and it showed the dead screen so maybe the remaining charge just needed to drain before I could turn it on :) KEEP COMMENTING for others who may have this same problem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
The 5S requires that you place all of the screws in the right place. They all have different lengths, sometimes only differing by 0.1mm. But if you put a long one in the wrong place, you can kill the logic board. Check out the guide to see if you possibly made this mistake.
The other common issue is when the battery is not disconnected prior to removing the screen. This usually affects the backlight circuit but it can cause other problems.
Go back through this guide and double check everything.
Esta resposta foi útil?
Pontuação 1
hi niannna
1st check the battery voltage minimum voltage is 3.6v if its not there change the battery or boot the your old battery and check.....
2nd check power flexi cable any damage
3rd connect to itunes its detecting or not in system
if its detecting pls let me know
Pontuação 0
Adicionar a sua resposta
Niannna será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 68
