Ir para o conteúdo principal
uma câmera compacta "Travel Zoom" anunciada em 31 de janeiro de 2007 como sucessora da TZ2.
no image on LCD
the LCD displays settings etc. correctly, but no image. Everything else appears to be OK.
please help!
Esta é uma boa pergunta?
Pontuação 1
5 comentários
Hi, Can you take a picture (I know you cannot see it in the screen) and then see if it is OK when you download it to a pc?
por Compartilhar
Hi jayeff,
thanks for your prompt response.
I have just tried that and the result is a black screen, no image.
Faulty CCD? Loose connection?
por Compartilhar
Jay Eff I have just now encountered on my Panasonic DMC- TZ3 a blank rear screen ., IT does however take pictures.. THE Blank Rear LED Screen is real Faint.. Of Course the First time I ever dropped it, while in the case did Not help Matters as it was working fine this Morning ..... I love the Camera
por Compartilhar
Jay , my camera still takes, receives, Flashes all pictures ,, but the Rear Screen, I have to put a Light on from another source to see the Menu ... DOES THIS MEAN a LAMP, or LED SCreen Problem ?
por Compartilhar
hi
the menu options looks well
only the screen in photo mode is black and as i shoot a photo all is black the photo saved is black
(if the lcd doesnt work the photo and the camera works should be visible after shooted the photo saved on the sd card
or isn it ?)
my doubt is to buy ccd sensor or lcd whole piece
thanks
por Compartilhar
Adicionar um comentário
2 respostas
Solução escolhida
Hi,
It seems most likely that you have a faulty CCD sensor.
Here is a link to a video that shows how to replace the CCD sensor in your camera. It is in German but the video is self explanatory.
https://www.youtube.com/watch?v=coM_V7kg...
Here is a link to a supplier of the CCD sensor. It is not a recommendation to use the seller, it is merely shown to give an idea of the cost of the part and a close up view of what it looks like. There are others online that may suit you better. just search for panasonic lumix dmc-tz3 ccd sensor
http://www.ebay.com/itm/Original-New-ima...
Hopefully this is of some help.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Hi @ stefano de santis,
If you can view the menu screens OK in the LCD screen itself then the screen is OK.
If the picture are just black images in the screen and also when downloaded then most probably there is a problem with the CCD sensor.
It could be an operating problem between the motherboard and the sensor but you won't know where it is until one or the other is changed.
As most of the other functions appear to be OK e.g., ON/OFF operation, menus, downloading etc, chances are that the problem is with the CCD sensor.
If you have a Lumix DMC-TZ3 use the answer above to replace the sensor.
por Compartilhar
Hi @wisconsingary ,
Assuming that the menu options are also not easily visible you could check that the LCD and / or backlight flex cables have not been jarred loose from the motherboard connector.
It it all appears to be OK then hopefully it may be a faulty LCD screen/backlight and not a problem on the motherboard. By your description "... Screen is real Faint.....", it is more likely to be the backlight that is the problem (smaller flex cable). Even if it is it cannot be repaired as it is integral to the LCD screen, which would have to be replaced
Here is a link to the ifixit Substituição do display LCD da câmera Panasonic DMC-TZ3 guide (or a You Tube video if you prefer) that shows how to replace the LCD screen.
The screen is available online, Just search for Panasonic DMC- TZ3 LCD screen replacement part to get results for suppliers that suit you best.
UPDATE
Hi @wisconsingary ,
It means that there is a backlight problem.
If the problem is found to be in the screen and not the flex cable connection or the motherboard, then the LCD screen will have to be replaced, as the backlight is integral to the LCD screen and is not a separate repairable component.
As a DIY repair it may be easier to replace the screen first and hope that the problem is in the screen than to try and find out if the power is being supplied to the backlight or not. Without a schematic, there is the potential to cause more problems whilst testing.
Pontuação 0
Adicionar a sua resposta
Ernst/Mada Brinkmann será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 76
Ao todo: 21,095
