Ir para o conteúdo principal
Apple Watch Series 2, announced September 7th, 2016 and released September 16 2016.
132 Perguntas Visualizar todos
Where is the button flex assembly connecting to the rest of the watch?
I'm a Product Designer and currently I'm working on a project that includes embedding an Apple watch. Because of this I'm researching about the components and structure of the watch. I found most of the information, but I couldn't figure out exactly where and how the button flex assembly is connecting to the rest of the watch.
Thank you so much for making the teardown video and pictures, it's very helpful and interesting.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
If you look at these two pictures you can see the IFIXIT Teardown team had a hard time taking the watch apart as they ripped the cable connection off ;-{
Esta resposta foi útil?
Pontuação 1
3 comentários:
Thank you! So it's a permanent connection, it can't be disconnected and then reconnected?
And what is the purpose of the small part on the left of the button flex assembly?
Also, I red at an Apple patent that the rotation of the Digital Crown is sensored with a Hall-effect sensor. Is this true? Do you know where this sensor could be located?
Thank you very much for your answers.
por
I'm just an eagle eye'd person who noted the discrepancy when the teardown was first published.
I think it would be best if you got a watch to take apart for your self.
If I read between the lines here you want to take the guts out and put it into something else. Remanufacturing is always a tricky thing doing one or two might work for fun, but trying to make a business doing it I think is just not worth it.
Have you looked at the Raspberry Pi products? They may offer a better foundation than trying to modify the Apple Watch. Once you build your product you can get the parts and build your own small package system.
por
My project is to create one individual object, where the Apple watch will be embedded. So I'm not planning on making a business out of this. I just need to make small modifications on the watch to incorporate into the design.
Thank you for your answer!
por
Adicionar a sua resposta
Hajnal MacGill será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 78
