Ir para o conteúdo principal
The OP-1 is a portable music workstation incorporating a synthesizer, sampler, sequencer, multitrack recorder, drum machine, mixer, and controller. It was released in 2011.
Why does the lower half of my keyboard not trigger?
Hello. The lower half of my keyboard on op1 is not working. Also my USB port has pushed through housing. Does anyone know how I can fix it or where I can have it fixed? Thank you
Chris
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Non-working, or intermittently working keys are most likely due to a glitch in the connection between the OP-1 Keyboard and the rest of the unit. If you want to try to fix this yourself then we suggest that you follow this guide. Basically start by removing the keys to uncover the screws, unscrew and lift the keyboard module, then remove and reinsert the connectors. Sometimes this resolves the issue, at least temporary, and a keyboard replacement is not needed. Good luck!
Please note: You will void any remaining warranty by doing this.
Imagem de Replace the Teenage Engineering OP-1 keyboard module and fix an unresponsive key. This part includes 12 loose keys.
Produto
OP-1 Keyboard
$119.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Chris leidy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 5
Ao todo: 678
