Ir para o conteúdo principal
Water Damaged iPhone 6 no sound, Can’t Record Video, Cant Record Voice
Hi I have a water damaged iPhone 6 in fact the screen was damaged also.
In attempting to repair the phone I have done the following
• Replaced the Screen and swapped the TouchID through
• Replaced the loudspeaker
Everything on the phone now works perfectly with the exception of sound. I am unable to record video recorder voice memo play back video that has sounds. One of the diagnostic apps on the App Store tells me the microphone is working fine that’s Why I replaced the loudspeaker. However I’m at a loss now to troubleshoot and identified the faulty part it could be the lightning connector and headphones jack as it contains a microphone.
Or
The Front camera sensor cable it to also contains a noise cancelling microphone.
No sound coming out of the headphones either?
Strangely I was also getting the following and adjusting the sound via the volume switches which I’ve never seen before.
Any and all help appreciated
-A
Esta é uma boa pergunta?
Pontuação 0
1 comentário
What components are on the audio control cable on the iPhone 6? And could the failure of these components cause the speaker to stop working?
por
Adicionar um comentário
1 resposta
Solução escolhida
There are three microphones on an iPhone 6:
  • The one at the bottom of the device next to the lightning port. It is used for phone calls, voice memos and selfie videos
  • The one near the ear speaker is used for noise cancellation
  • One next to the flash/camera for videos with the rear camera.
Identify when you can or can't record video to identify which microphone is problematic. Use headphones to isolate the speaker or try to email the recording so you can listen to it on a computer.
You should be able to isolate the problem. If none of the microphones or speakers work and you have replaced parts, then your problem may reside on the logic board. There are amplifier circuits that may have been damaged by corrosion.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks this is helpful when i say i cant record video or record a voice memo its not that it records nothing its the recording does not start at all.
por
Adicionar a sua resposta
Alan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 8,096
