Ir para o conteúdo principal
O Honda Civic de sexta geração foi lançado em 1995. Ele manteve a dirigibilidade líder da sua categoria, já que, assim como as quarta e quinta gerações, possuía suspensão dianteira double wishbone, uma suspensão independente avançada inspirada nas pesquisas de corrida da Honda.
Car turns off while driving.
My car won't stay on while I'm driving. Sometimes the car won't turn on at all. I have bought new plugs, cap and rotor, and alternator, still no luck. Please help!
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Hi, Take the vehicle to an AutoZone store (if in the USA - they do it for free apparently) and get the OBDII port scanned to see if there are any fault codes there which may give you an indication of what the problem is.
por Compartilhar
Adicionar um comentário
3 respostas
Pergunta mais útil
Anecdote:
My civic died while driving.. wouldn't start.. after it cooled down a bit, it turned right back over... only to die again after idling for a minute..
turned out replacing the distributor fixed it... i landed on that after a lot of googling... people said the igniter inside the distributor is likely bad, and when it heats up it fails.
I see you posted this in january, so....
Esta resposta foi útil?
Pontuação 2
My honda civic stalled while driving it started back up I went on it stalled again 6times till I got home cooled down last 2 days ran fine help
Pontuação 0
1 comentário:
I have been having problems with starter going to replace tied tapping starter may have very lightly touched distributer don't thing I damaged it definitly didn't crack it could this have caused my problem
por Compartilhar
Have you checked the battery? If so then check your starter fuse.
Pontuação 0
Adicionar a sua resposta
Jhou'quan Glenn será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 34
Ao todo: 2,707
