Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
1233 Perguntas Visualizar todos
iPhone not powering on but gets hot (not logicboard)
I have an iPhone 5c that I have refiently refurbished however when I come to turn the phone on there is no response. I have left the phone on charge and it seems to get warm. It is not the logic board as I have taken the logic board out and tried it in another phone and it works fine. I have plugged the unresponsive phone into my laptop and iTunes is picking it up. Any ideas?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
I forgot to mention I have also tried different screens so it could not be the screen
por
Have you tried a different battery?
por
Adicionar um comentário
1 resposta
Solução escolhida
I think you need to retrace your steps. Look at all the variables and try to eliminate them one by one.
You confirm the logic board works and that the screen works but that the two don't work when they are together in the same housing. If that is true, then it sounds like the problem is related to the housing. There must be a problem with the grounding or a flex is pinched.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
CustomPhoneUk será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 72
