Ir para o conteúdo principal
The Xbox One Wireless Controller model 1697 was released in 2015 and replaced the model 1537 controller and fixed some of the problems found on Model 1537 controllers. The Model 1697 controller includes an integrated 3.5mm headset jack, which allows compatibility with most 3rd party headsets without the need of an adapter. This controller has been discontinued and replaced by the Model 1708 controller.
75 Perguntas Visualizar todos
Is there a fix for directional "wandering" on Xbox one controllers?
On all three of my XB1 controllers the arrow, reticle, or avatar will move or wander on its own even when not touching thumbsticks: IS THERE A FIX FOR THIS?? or is this how MS gets an extra $70 out of each Xbox owner every few months? ANYONE??
Esta é uma boa pergunta?
Pontuação 10
4 comentários
its fairly easy to fix you need to replace the entire stick mechanism inside the controller itself. I just did this job myself, follow the guide for tear down and simply de-solder all 14 points push out from the bottom insert the new mechanism and resolder the devices pins back to the board.
por
You don’t have to take all the points off just find out which one is bad and just take the three points off and then replace that part the green part snap on and off really easy
por
is there not a hard reset like the good old controllers???
por
How do you plan to "reset" a hardware issue?
por
Adicionar um comentário
3 respostas
Solução escolhida
If your Xbox One Wireless Controller has a malfunctioning thumbstick and you cannot properly navigate around your Xbox One, see the Xbox One Wireless Controller Has Malfunctioning Thumbsticks problem page for possible problems and solutions.
Esta resposta foi útil?
Pontuação 2
3 comentários:
they always seem to start that wander around 4-mos or so "surprise" warranty is 3mos ,btw have you heard of "levity"or do you owe MS something?b'cuz I sure don't,but thanx for nothing tom
por
Interesting. Xbox One controllers are warranted for 1 year here. If you do want to fix it you have to replace the joystick module, which should be available on Alibaba or somewhere. Disassembly and soldering required.
por
Well...u can take the controller apart, super clean the analong bases...rubbing alchohol works....clean teh crap out of it...fixed mine.....
por
Pergunta mais útil
yes you can fix it but you have to be willing to strip down the controller, on a part of the joystick there is a place for a little flat head screwdriver, you have to turn it slightly for it to change the vertical or horizontal scrolling.
Pontuação 4
Yes. It's just a cleaning issue.
Pontuação 0
Adicionar a sua resposta
voodoo24u será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 45
Duração total: 26,392
