Non-Unibody, Core Duo & Core 2 Duo Processors
476 Perguntas Ver todas
MacBook Pro A1151 17" 2.16GHz CD Logic Board 820-2023-A
Hi
Sorry my English it's not too good, by I'll try to explain my problem .
I've got a Macbook pro 17" with this generalized problem, distorted video and glitches.
http://torley.com/macbook-pro-with-a...v... --> explanation
Treated on this thread too --> http://discussions.info.apple.com/th...2...
I tried all that stuff, but no luck of resolving the problem at this moment.
I thought i could try get a new logic board and ind the case get a higher one,
but i don't know if will be possible swap the old one with a higher model.
My actual model is this one.
MacBook Pro 17" (Model A1151) 2.16 GHz Logic Board
And i would like to get one of those higher model's.
MacBook Pro 17" (Model A1229) 2.4 GHz Logic Board
MacBook Pro 17" (Model A1261) 2.6 GHz Logic Board
it's possible to swap the older model that I've got the first one that has a core duo processor with the latest ones with a core 2 duo and faster processor ?¿
The chip-set looks pretty similar in shape and size.
Thx in advance.
P.D: I have to practice more my English. I'm from Spain by the way.
MacBook Pro 17" (Model A1151) 2.16 GHz Logic Board Imagem
Produto
$499,99
MacBook Pro 17" (Model A1229) 2.4 GHz Logic Board Imagem
Produto
$379,99
MacBook Pro 17" (Model A1261) 2.6 GHz Logic Board Imagem
Produto
$999,99
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
4 Soluções
Solução escolhida
After looking at the prices on these boards $750-850, consider using someone like DT&T services. They will repair your logic board for $350. http://www.dttservice.com/macbookprosilv...
Esta resposta foi útil?
Pontuação 2
Hi, I would like to offer you this suggestion but first I must ask you a questions; 1) have this unit ever had any type of a heating issue (been hot at some point in the past) and 2) have you or anyone been inside of the "top cover (in other words, have the top cover with the key pad been opened up)?" If so then it is possible that the screen cable may have some loose wire connections within that part that plugs into the logic board. This cable is on the right side of the board just below the fan towards the left (it have around 10-12 different color wires going into one connector).
You can remove that connector by pushing it out and lifting it up then hold the metal connector end with one hand and with the other, just grab the entire section of those wires and give them a slight twist (back and forth) and then PUSH the wires (with a very small amount of pressure) into the metal piece in your other hand. Now without DISTURBING that connector, lay it back down to the socket that it came from, line it up with that part on the logic board and push it in gently by the VERY outer edges ONLY. Place the top cover back down (don't screw anything down yet), turn it on and see what you get. If it looks okay, then just let it run while you try out your videos. If those old problems don't show up any more then you can celebrate and dance.
Pontuação 0
because those latest procesor will support install of mavericks...
so... can i install the a1261 logic board into a a1151?
Pontuação 0
Before buying a new board, look for example at ebay. Some people offer to repair those kind of problems. Look for laptop reballing . Some include exchanging defective gpus if the problem isn't the soldering points
Pontuação 0
Adicionar a sua resposta
oscarroro será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Todo: 3,360
