Ir para o conteúdo principal
O AKASO KingPad A90 é um tablet de 9 polegadas com processador dual core. Ele possui 8 GB de armazenamento interno, executa o Google Android 4.2 Jelly Bean, tem câmera frontal e traseira, alto-falante traseiro e suporte para saída HDMI. Este dispositivo foi lançado em 31 de outubro de 2013.
How can I replace the headphone jack?
Headphone jack not working on KingPad tablet. Jack is not clogged.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
you can fix it by going to an tablet shop
Esta resposta foi útil?
Pontuação 0
2 comentários:
hey guys this is my first time doing this and the reason i am doing this is because i love helping others
por
@azellya ,
That's fine but first try helping by providing an answer that allows the OP to try and fix the problem themselves.
After all that is the name of this forum I - FIX - IT (ifixit)
e.g. if you click on the device icon at the top right of this page, you will find links to the ifixit repair guides for the tablet.
You could suggest that they use the guides to open the tablet so that the headphone socket can be inspected. maybe it is just loose from the systemboard and can be resoldered back on or if it appears to be OK perhaps you may be able to find a compatible replacement headphone socket supplier online etc. that you could link into the answer.
Advising the OP to contact a professional repairer is OK but not in the first instance. Most people would already know to do this anyway and wouldn't come to this forum just to hear what they already know .
View how others answer questions on this forum, especially those with a high reputation count (look under the avatar for the Rep points) to get an idea of what may be required in an answer.
Your motives are good keep it up.
Cheers
por
Adicionar a sua resposta
lgadzinski será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 27
Ao todo: 444
