Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
Touchscreen stopped working after screen replacement
i just replaced screen on my iPhone 5s. This phone does not have SIM card, it was transferred to another phone. The screen is lit, charger is working, I can turn screen on and off. The problem is that my screen does not respond to any touch finger command including "slide to power off"
HELP!!!
Leon2472
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
You probably didn't connect the digitizer properly. This is the digitizer connection. Go back and insure it is properly connected. And don't mix up the screws to the bracket or you could cause severe damage.
Esta resposta foi útil?
Pontuação 4
2 comentários:
This was excellent advise to properly reconnect digitize cable. The touch screen is now working.
The new problem: This is 5s phone. During the start up the screen lit normally but after the apple goes away, the screen goes dim and stays dim .
Any advice?
por
go into settings and turn the brightness up. If the brightness toggle is not working, its possible that the flex with the front camera and light sensor has a tear. Its also possible that the light sensor is not situated correctly.
por
Display and touch pmu problem, or battery high voltage 4v-4,2v, normally 3,8v. If battery high voltage, output display pmu high. Check u3 and Vbat = Vcc
Pontuação 0
1 comentário:
This was already answered more than a year ago. So you really dont need to post here also your answer is kind of confusing. where is the u3 located? Whats a pmu?
por
Adicionar a sua resposta
Sanevich será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 16
Duração total: 357
