Ir para o conteúdo principal
Anunciada em outubro de 2013, a Nikon D5300 é uma câmera DSLR de nível básico superior com um sensor DX de 24 MP.
"Zoom Out /? " Button is unresponsive.
Zoom Out / ? Button is automatically pressed even without touching. When double pressed of pressed hard it keeps responding neatly for 5 mins tops. and after same problem. Do I have to replace the back panel key board or any repairs can done by myself? Please help me out.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
it is most likely that there is dirt or something causing the button to stop working or to start working randomly of it own accord. you'd need to remove the back cover to expose the button contacts and give them a good clean, worst case scenario you'd be buying a rear cover button flex cable fpc.
it can be a fiddly job with screws hidden all over the place, there is no guide on iFixit to do this but there are guides for similar models like the D5200.
follow this guide to removing the back cover, once you have the back cover off its a pretty simple job to remove the ribbon cable and clean or replace.
Nikon D5200 Motherboard Or Camera Back Replacement
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Amila Yohan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 1,248
