Ir para o conteúdo principal
Nikon D5200 Motherboard Or Camera Back Replacement
O que você precisa
  1. Nikon D5200 Motherboard Or Camera Back Replacement, Remove Battery, SD Card, Bottom Screws.: passo 1, imagem 1 %32
    • Remove the three 3.5-mm screws from the underside of the camera that are circled.
    • Remove the battery, and any SD card that is in the camera.
  2. Nikon D5200 Motherboard Or Camera Back Replacement: passo 2, imagem 1 %32 Nikon D5200 Motherboard Or Camera Back Replacement: passo 2, imagem 2 %32
    • Remove the 7-mm screws from either side of the camera.
  3. Nikon D5200 Motherboard Or Camera Back Replacement: passo 3, imagem 1 %32 Nikon D5200 Motherboard Or Camera Back Replacement: passo 3, imagem 2 %32
    • Gently pry back the rubber pad on the back of the camera with a metal spudger or other tool, or your fingernail, to reveal a hidden screw.
    • Remove the 4-mm screw.
  4. Nikon D5200 Motherboard Or Camera Back Replacement: passo 4, imagem 1 %32 Nikon D5200 Motherboard Or Camera Back Replacement: passo 4, imagem 2 %32 Nikon D5200 Motherboard Or Camera Back Replacement: passo 4, imagem 3 %32
    • If a rubber guard is present around the viewfinder, press upward on the guard to remove it.
    • Remove the three 7mm screws around the viewfinder.
  5. Nikon D5200 Motherboard Or Camera Back Replacement: passo 5, imagem 1 %32 Nikon D5200 Motherboard Or Camera Back Replacement: passo 5, imagem 2 %32 Nikon D5200 Motherboard Or Camera Back Replacement: passo 5, imagem 3 %32
    • Carefully use a metal spudger to remove the cap from the dioptric adjustment dial to reveal a screw. Note that you are only removing the cover -- the insert on the dial that has the "+/-" on it -- not the entire knurled ring.
    • Remove the 12-mm screw.
  6. Nikon D5200 Motherboard Or Camera Back Replacement: passo 6, imagem 1 %32 Nikon D5200 Motherboard Or Camera Back Replacement: passo 6, imagem 2 %32 Nikon D5200 Motherboard Or Camera Back Replacement: passo 6, imagem 3 %32
    • Once all screws have been removed, carefully pull the casing apart. Take care not to pull any wires apart.
  7. Nikon D5200 Motherboard Or Camera Back Replacement: passo 7, imagem 1 %32 Nikon D5200 Motherboard Or Camera Back Replacement: passo 7, imagem 2 %32 Nikon D5200 Motherboard Or Camera Back Replacement: passo 7, imagem 3 %32
    • Use a plastic opening tool to unplug the two ribbon cables connecting the two parts of the casing.
    • The orange-brown ribbon cable has a tiny brown plastic latch/door that flips up to release the cable. The silver ribbon is simply pressed into place; the ends are the safest point to gently pry it off to avoid damaging its wires.
    • If you are only replacing the camera back, stop here and reverse the preceding steps to install the new back.
  8. Nikon D5200 Motherboard Or Camera Back Replacement: passo 8, imagem 1 %32 Nikon D5200 Motherboard Or Camera Back Replacement: passo 8, imagem 2 %32 Nikon D5200 Motherboard Or Camera Back Replacement: passo 8, imagem 3 %32
    • Remove the 3.5-mm screws around the edges of the metal plate covering the motherboard.
    • Pull the metal plate off and away from the motherboard.
  9. Nikon D5200 Motherboard Or Camera Back Replacement: passo 9, imagem 1 %32 Nikon D5200 Motherboard Or Camera Back Replacement: passo 9, imagem 2 %32 Nikon D5200 Motherboard Or Camera Back Replacement: passo 9, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to remove the small cable in the top-left corner of the motherboard from its socket.
    • Use a plastic opening tool to unplug the remaining ribbon cables.
  10. Nikon D5200 Motherboard Or Camera Back Replacement: passo 10, imagem 1 %32 Nikon D5200 Motherboard Or Camera Back Replacement: passo 10, imagem 2 %32 Nikon D5200 Motherboard Or Camera Back Replacement: passo 10, imagem 3 %32
    • Remove the motherboard from its seat and lift it up.
    • Unplug the red and blue wires from their socket.
  11. Nikon D5200 Motherboard Or Camera Back Replacement: passo 11, imagem 1 %32 Nikon D5200 Motherboard Or Camera Back Replacement: passo 11, imagem 2 %32
    • Desolder the small wires in the upper-left corner of the motherboard.
    • Soldering irons become very hot when in use. Take all necessary precautions to avoid injury.
Conclusão
16 outras pessoas executaram este guia.
Alexander Corn
Membro desde: 08/26/15
1.312 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 3-1, Eyestone Fall 2015 Membro de USF Tampa, Team 3-1, Eyestone Fall 2015
USFT-EYESTONE-F15S3G1
4 Membros
Autoria de 5 guias
7Comentários do guia
How did you remove the cap from dioptric adjustment dial without braking the cap in step5?
cghh dbv - Responder
there is a sticker above it you've to remove the sticker not the whol cap, the under the sticker you will see the screw
prince.x96 -
I soaked the back of my camera, which fried the LCD and one of the buttons. Bought a new back on eBay for $60 and used this to replace it in about an hour. This might be the preferred way to replace the LCD for some folks, to avoid having to what appears to be a fairly delicate desolder-resolder to replace only the LCD. As of the time of this comment, the parts cost a little bit more -- like $20 for LCD vs $60 for the full back, but not prohibitively so.
Joseph Morris - Responder
Does the motherboard which I ordered from aliexpress work in a camera which i bought in moscow russia??
Mathias - Responder
Does the motherboard which i ordered from aliexpress work with a camera nikon d5200 which i bought in moscow russia?
Mathias - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 81
Ao todo: 11,118
