Ir para o conteúdo principal
O Moto G4 Plus é uma melhoria do Moto G4 da Motorola. O Moto G4 Plus oferece um sensor de impressão digital, maior capacidade de memória e uma câmera traseira aprimorada. Números de modelo XT1642 e XT1644.
moto g4 plus Micro USB Replacement
Can you put up a video on how to replace the micro usb port on the moto g4 plus?
Mine had the plastic literally melt after connecting in to an apparently faulty car charger.
Much Thanks and keep up the great videos!
Esta é uma boa pergunta?
Pontuação 5
4 comentários
Your phone didn't warn you what was happening?
por
Hi, did you solved this problem? I need to replace my charging port too.
por
Nope, ended up sending it in on warranty and getting a new phone.
por
Hi
I purchased a rebuilt Moto G 1st generation smartphone but the charger port was broken after I paid for it , and before I received it.
Can you provide an instruction manual or video? I have seen one but the soldering alone I know is more than I can do myself. Can you help?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
william_oliveira87, John Linden, If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the tablet to check the charge port and will also post a link showing what is involved in repairing a USB charge port attached to the board. The last link is to new charge port, which you can also do a search for better pricing perhaps if needed. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck.
https://www.youtube.com/watch?v=8jqw-KwC...
https://www.youtube.com/watch?v=Bl_6g4GV...
http://www.ebay.com/itm/2X-Dock-Connecto...
Esta resposta foi útil?
Pontuação 7
Adicionar a sua resposta
John Linden será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 20
Ao todo: 10,932
