Ir para o conteúdo principal
Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
75 Perguntas Visualizar todos
Damage to touch - display loose
I believe my laptop may have been stood on and the right hand side of the display is loose, causing it to switch off continually. Do I need to replace the whole screen or can it be fixed? A new screen is expensive and mine isnt actually damaged, just loose.
Many thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Here is a link to the service manual for a Dell XPS 13 laptop.
In it you will find the pre-requisites and procedures necessary to remove/replace the display. By using this you can open your laptop and see what is the cause of your problem and possibly how to fix it.
http://topics-cdn.dell.com/pdf/xps-13-93...
Hopefully this is of some help
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
lisa kater será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 196
