Ir para o conteúdo principal
O mais recente celular da linha HTC One, simplesmente chamado de HTC 10, foi lançado em 2016.
How to replace the battery
How can you replace your battery of the HTC 10
Esta é uma boa pergunta?
Pontuação 12
27 comentários
Hi,
Just curious why you would want to replace the battery on a phone (which for warranty purposes includes the battery) that should still be covered by the manufacturer's 12 month warranty as it was only released in Apr/May 2016.
http://dl4.htc.com/Web_materials/Manual/...
There is also this Uh Oh Protection addendeum to the warranty if you purchased the phone from HTC.com
por Compartilhar
@jayeff , its funny how this question got hijacked and became a Samsung commercial. You probably should post your comment as a solution.
por Compartilhar
Hi @avanteguarde ,
As you say they're not really offering solutions to the question asked or even asking the same sort of question again as sometimes happens.
Perhaps they should be marked as off-topic at the least.
Cheers
por Compartilhar
@jayeff, yes, I've already voted, just need a few more votes.
por Compartilhar
mine started doing the same thing. It seems to shut off on its own. When it does restart it says 33%. I shut down phone cometely and restart and it says 2-3%. From full charge my phone does this almost everyday. Trying to find answers also. Warranty ended in September and this started happening less than a month later.
por Compartilhar
Exibir mais 22 comentários
Adicionar um comentário
8 respostas
Pergunta mais útil
I thought I may have had to replace my battery too. Was going to go down the warranty route.
My phone seemed completely non responsive to charging, powering on or anything.
Spoke with O2 and was advised to press and hold the Power button and volume down for 10 seconds.
This brought up a 'reboot' screen. It mentioned something about the phone being locked.
I used the volume up and down to select the Reboot option and then the power button to select the option.
Phone rebooted very quickly and was immediately back to working as normal.
Hope this helps, if you have the same problem.
Esta resposta foi útil?
Pontuação 12
6 comentários:
i registered to this site, just to thank you because my htc just had the same issues and fortunately your help worked perfectly fine to me.
thank you so much
por Compartilhar
I did everything here. Worked a few more weeks then went black. No light. No charging ability. No power on. It's basically a brick. I bought a quick, lesser expensive phone, LG Stylus 3. Still would like to get phone to work again at least for extra Wi-fi device. I paid enough for it.
por Compartilhar
Thank you so much for posting this! I had the same problem. Phone was at 48%, then turned itself off, was unresponsive to power button or charging or anything. I thought I was going to have to spend money I don't have to get it fixed, but happened across your comment, and it worked like a charm :) thanks so much!
por Compartilhar
Thank you dido to all the above. I was about to by a new battery. This worked like a charm
por Compartilhar
follow instructions using power and volume up and down keys for
CLEAR CACHE PARTITION. reboot to download and recovery modes
por Compartilhar
Exibir mais 1 comentário
Ifixit has a tear down guide for the HTC 10. You can use this to change the battery.
Desmontagem do HTC 10
Pontuação 6
if you have warranty service, go with that. If you don't, the guide's here:
http://www.etradesupply.com/blog/htc-10-...
but seriously. This is one of the most ridiculously hard phones to repair.
Pontuação 2
I have these issues plus including all icons disappearing, running extremely sluggish, date stamps missing on SMS messages, now when I tap any key or app it no longer vibrates except during a call or text alerts, and since dec 2017 the phone goes thru a bunch of sound effects and buzzing about 3-4 times a day and back some months ago the phone heated up to 121 degrees and afterwards all these above problems started and back in 2017 the micro sd card disappeared but accessible thru my laptop but the card is encrypted so even tho the laptop sees it I can not gain access to the files. Going back to feb 2017 I started taking bug reports and sending em to the sd card and after the card was no longer available I started sending the bug reports to my google drive. I have had it with my HTC 10... my HTC Evo 3D still works fine just upgraded it as it got old and I have a need for speed no matter if it's my pcs of phone
Pontuação 0
1 comentário:
SD cards brake when getting older. Especially if ur constantly doing write cycles like on a phone
por Compartilhar
Watch this, it’s a hassle though. I’m also contemplating a new battery. It only holds 61% of the original 3000mah capacity. I mucked it up after leaving it on the charger for 12hs on multiple occasions. https://www.youtube.com/watch?v=T5uLJJnE...
Pontuação 0
If I reboot my htc phone will I loose my data???
Pontuação 0
1 comentário:
No, no data is lost by doing this but if you do something and brick it... Just backup to be safe
por Compartilhar
Search for Any YouTube Tutorial. You will Find Many One.
Pontuação 0
Square Repair in London will replace an HTC 10 battery for £58.50 including return postage - you just post it to them.
Pontuação 0
Adicionar a sua resposta
[deleted] será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 16
Últimos 30 dias: 43
Ao todo: 56,767
