Ir para o conteúdo principal
A primeira geração do Audi A4 estreou em outubro de 1994. O A4 de 1995-2001 foi construído na plataforma B5 da Volkswagen.
dashbord is not working
hi
i have an audi A4 1996 , suddenly the rpm , speedometer , temperature , gaz level and all other indicator was disappear , but the car steel running ,
any idea why this is happen ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Hi,
Have you checked in the fuse panel, that the fuse for the instrument cluster is OK?
Here is a link which shows the fuse box location and the allocation of the fuses. The fuse marked as Fuse #5 "Control unit for Instrument Cluster is the one you have to locate.
If you replace the fuse and it 'blows' immediately or shortly after, there is a problem and it should be checked out by either an auto electrician or an Audi dealer to find the cause..
It may be also have been simply that the fuse has simply failed. There are a few causes: fatigue due to age,mechanical failure of the fuse due to vibration etc.
https://www.manualslib.com/manual/396576...
Esta resposta foi útil?
Pontuação 1
Audi Dashboard Warning Lights: Their Significance and How to Respond
Pontuação 0
Adicionar a sua resposta
elie será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 36
Ao todo: 9,007
